where to insert the lockup latches
owen_li
Full Member level 3
As we know, we should insert lockup latches between cross clock domains to avoid hold violation.
My question is: Should we insert the lockup latch on the shift path or capture path.
The shift path means from Previous register output to next register scan input
The capture path means from Previois register output to next register D input.
My understanding is: these two pathes both have the potential to fail the hold check
because of the clock skew. Should we insert the lockup latches on both paths?
Thank yoU!
vlsichipdesigner
Full Member level 2
India
hi,
my 2 cents,
We apply the lockup latches, only to scan-shift path to address hold violations.
scan -capture,would get addressed in functional mode and the probability of hold violations is less.
myprayers,
chip design made easy
https://www.vlsichipdesign.com
    V
owen_li
Full Member level 3
thank you for your response! vlsichipdesigner
I am still curious of this issue.
In my opinion, we will usually set false path between clock domains, except the synchronous clock domains.
So the functional timing mode run will not care these hold violation between clock domains. But when in the test timing mode, these hold violations will come out!
How do you handle this situation ?
Thanks!
Added after 8 minutes:
Thanks!
    V
jaydip
Member level 3
see, if functional path is valid, why will anyone define it as a false path?? and if it functional path is valid, hold and setup violation will anyhow be taken care .. is it not?
raju3295
Full Member level 4
hi jaydip,
Its a false path in the functional mode but valid path in the testmode.
jaydip
Member level 3
if these paths are clock domain crossing paths (defined as false path in functional mode), lock-up latch takes core of hold violation in test mode and synchronizers takes care of hold violations in functional mode .. what are others path which are false in functional mode and valid in test mode? I hope make sense ...
h.edaboard
Junior Member level 1
Hi, I'm a new member here.
I think your question should be solved with MMMC, multi-mode multi-corner.
if in test mode, the tool sees the hold violation, it will automatically take care of it.
Thanks!
Thanks!
arunkumar446
Full Member level 3
Hi jaydip,
can you elaborate on synchronizers and can you refer me to any papers and docs related to synchronizers and lockup latches.
Thanks in advance.
raju3295
Full Member level 4
i think multicycle paths in the funcctional paths are false path in testmode.
arunkumar446 said:
Hi jaydip,
Thanks in advance.
synchronizes are nothing but like shift registers kept between the clock domain crossing paths , clocked by capturing clock
arunkumar446
Full Member level 3
arunkumar446 said:
Hi jaydip,
Thanks in advance.
Hi, can you give me an example or refer me to some doc which has an example in it.
thanks in advance.
raju3295
Full Member level 4
sorry i did't get for what ur asking reference
pete_lu
Junior Member level 2
Thanks!
Thanks!
MMMC is the right answer, we don't need to insert lockup cells in scan-capture path since hold violation in scan-capture mode will be fixed in scan-capture mode analysis!
And scan cts will be implemented after function cts, so we don't need to take care of clock skew in scan capture mode.
rakko
Full Member level 4
mozambic
The sole purpose of lockup latch is to allow reliable shifting in scan shift mode and therefore is not necessary to put them in functional paths. When we de-assert scan+enable, the chip temporarily comes out of the scan and enters functional mode. If the functional mode does not have hold violations, then, you shouldn't see any in test mode either. I think someone mentioned some of this earlier.
owen_li
Full Member level 3
Thanks for your response.
But I think there are indeed some pathes valid in test mode, and invalid in functional mode.
I mean these pathes' timing check will be don't cared, like crossing clock domains.
But when running in test mode, the output of previois clock domain should be captured by the latter clock domain. So the path is valid in test mode.
How can you guarantee the path is absent of hold violation ?
