where to find rtc programs using Dallas DS1307?
weifeng
Junior Member level 1
c18 ds1307
hi,
i need to find an RTC program using DS1307 chip. I am using PIC18F452, MPLAB IDE/C18 compiler. Can any one tell me where can i find it? thanx.
ds1307 and hitech c
I am afraid I do not understand the question.
The DS1307 is the RTC. All you need to do really is use the I2C interface to read/write the register.
ds1307 c18
hi. thanx for the website link. its the program i m finding. thanx a lot. :)
ds1307 pic18f
Hello,
If you are using CCS C compiler you will get sample code for DS1307.
Bye
program for rtc in c
hi all. reali thanx for all the help given. :)
programme for i2c ,ds1307
hi,
regarding abt tis website=http://www.sixca.com/micro/pic/ds1307/
the source code in it, i got sum parts of the statements don't quite understand it.
what is the #use
#fuses
#use ????
anyway while trying to interface wif my chip, this part cums out as an error.
so does anyone know how should i modify it?
thanx.
c program real time clock ds1307
I just now work with DS1307 on my four 7-segment clock project. Here is code. I write it in Hi-tech C for PIC.
first declare:
unsigned char rtcvalue_bin,rtcvalue_bcd,rtcreg;
unsigned char rtensec,rsec,rtenmin,rmin,rtenhour,rhour,rday,rtendate,rdate,rmonth,rtenmonth,rtenyear,ryear;
void rtc_read(unsigned char *rtc_buffer);
Then:
void read_ds(void)
unsigned char rtc[8];
rtc_read(rtc); // rtc read subroutine
rsec=(rtc[0]&0x0f); // seconds
rtensec=(rtc[0]>>4);
rmin=(rtc[1]&0x0f); // minutes
rtenmin=(rtc[1]>>4);
rhour=(rtc[2]&0x0f); // hours
rtenhour=(rtc[2]>>4);
rday=(rtc[3]&0x0f); // weekday
rdate=(rtc[4]&0x0f); // date
rtendate=(rtc[4]>>4);
rmonth=(rtc[5]&0x0f);
rtenmonth=((rtc[5]&0b00010000)>>4);
ryear=(rtc[6]&0x0f); // year
rtenyear=(rtc[6]>>4);
void rtc_set(unsigned char rtcreg)
SEN = 1; // send start bit START
while(SEN); // and wait for it to clear
ACKDT = 0; // acknowledge bit
SSPIF = 0;
SSPBUF = 0xD0; // set device address 0xd0 // write SLAVE ADDRESS
while(!SSPIF); // wait for interrupt
SSPIF = 0; // then clear it.
SSPBUF = rtcreg; // register select rtc WORD ADDRESS
while(!SSPIF); //
SSPIF = 0; //
SSPBUF = rtcvalue_bcd; // write data to rtc DATA 0
PEN = 1; // send stop bit STOP
while(PEN);
void rtc_read(unsigned char *rtc_buffer) // i2c rtc read 8 bytes
SSPIF = 0;
SSPBUF = 0xd0; // set device address 0xd0 // write SLAVE ADDRESS
SSPBUF = 0; // read from address 0 = register 0, rtc WORD ADDRESS - control 1
RSEN = 1; // send repeated start bit REPEATED START
while(RSEN); // and wait for it to clear
SSPIF = 0;
SSPBUF = 0xd1; // set device address - read WORD ADDRESS - CONTROL 2
RCEN = 1; // start receiving READ & ACK buffer 0
while(!STAT_BF); // wait for data
rtc_buffer[0] = SSPBUF; // and get it // buffer
ACKEN = 1; // start acknowledge sequence
while(ACKEN); // wait for ack. sequence to end
RCEN = 1; // start receiving READ & ACK buffer 1
rtc_buffer[1] = SSPBUF; // and get it // buffer
RCEN = 1; // start receiving READ & ACK buffer 2
rtc_buffer[2] = SSPBUF; // and get it // buffer
RCEN = 1; // start receiving READ & ACK buffer 3
rtc_buffer[3] = SSPBUF; // and get it // buffer
RCEN = 1; // start receiving READ & ACK buffer 4
rtc_buffer[4] = SSPBUF; // and get it // buffer
RCEN = 1; // start receiving READ & ACK buffer 5
rtc_buffer[5] = SSPBUF; // and get it // buffer
RCEN = 1; // start receiving READ & ACK buffer 6
rtc_buffer[6] = SSPBUF; // and get it // buffer
RCEN = 1; // start receiving READ LAST & NO ACK buffer 7
rtc_buffer[7] = SSPBUF; // and get it // buffer7
ACKDT = 1; // not acknowledge for last byte
while(PEN);
In main program you must set up I2C bus and use this to start DS1307:
void main(void)
rtcreg=0x00;
rtcvalue_bcd=0b00000000;
rtc_set(rtcreg);
DelayMs(10);
while(1)
IT MUST WORK
ds1307 i2c c pic examples
hi,
the las part of the program which is to start up I2C bus, the "dot dots" in between and after must add in something rite? what must be added?
ds1307+pic+c
I wrote you that you need to start RTC before while loop, and in while loop write what you want. And before RTC block set up I2C registers.
program for the ds1307 real time clock
hi,
i tried the program, but den this:
'SEN' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:30:Error [1101] lvalue required
C:\Documents and Settings\user\My Documents\testing.c:31:Error [1105] symbol 'SEN' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:32:Error [1105] symbol 'ACKDT' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:32:Error [1101] lvalue required
C:\Documents and Settings\user\My Documents\testing.c:34:Error [1105] symbol 'SSPIF' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:34:Error [1101] lvalue required
C:\Documents and Settings\user\My Documents\testing.c:36:Error [1105] symbol 'SSPIF' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:37:Error [1105] symbol 'SSPIF' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:37:Error [1101] lvalue required
C:\Documents and Settings\user\My Documents\testing.c:40:Error [1105] symbol 'SSPIF' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:41:Error [1105] symbol 'SSPIF' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:41:Error [1101] lvalue required
C:\Documents and Settings\user\My Documents\testing.c:44:Error [1105] symbol 'SSPIF' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:45:Error [1105] symbol 'SSPIF' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:45:Error [1101] lvalue required
C:\Documents and Settings\user\My Documents\testing.c:47:Error [1105] symbol 'PEN' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:47:Error [1101] lvalue required
C:\Documents and Settings\user\My Documents\testing.c:48:Error [1105] symbol 'PEN' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:53:Error [1105] symbol 'SEN' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:53:Error [1101] lvalue required
C:\Documents and Settings\user\My Documents\testing.c:54:Error [1105] symbol 'SEN' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:55:Error [1105] symbol 'ACKDT' has not been defined
C:\Documents and Settings\user\My Documents\testing.c:55:Error [1101] lvalue required
C:\Documents and Settings\user\My Documents\testing.c:57:Error [1105] symbol 'SSPIF' has not been defined
Halting build on first failure as requested.
came out as error....
ds1307 pic c18
I have source code for keil complier (C51).
ds1307 program
there is an application note in dallas web site with code
ds1307 rtc c program with pic18 hitech
hi,
the source code in dallas i tried already, there are still errors...
rtc driver source code dallas
hi,
while trying to build my program, i stil face many errors in it...
anyone knows hw shd i change this: void read_clock(byte control_reg) ???
thanx.
ds1307 interca code in pic
can some one find error for this code?
use proteus, keil
ds1307 i2c hi-tech pic it must work
There are some good exmples at MichrochipC.com. It also includes one for real time clock interfacing....
