Register Log in
Where to find a JTAG connector in Farnell?
yassin.kraouch
Advanced Member level 2
have anyone an idea where can i found a JTAG connector in farnell?? this is the part number and i didn't find this product in farnell
Added after 3 minutes:
or if you have similar product in farnell
karesz
Advanced Member level 5
EU
JTAG connector
You will it so specifyed never find, then its not a direct standard...
In applications are 10 & 14 pin connectors common, i.e. Xilinx use both on the same board, than some product has as 2mm , others even as 2.54mm system...
Relative sure is only, that it is a pressed flat cable connector:)
K.
yassin.kraouch
Re: JTAG connector
i use 2.54 mm and 34 pin & 2 rail
