Where to download Ansoft Ensemble SV from?
svarun
Full Member level 5
In the warm company of God's most exquisite creati
Hi all,
I need to simulate a couple of microstrip antenna designs.I
am told that Ansoft Ensemble SV ( Student version ) is a good tool to
work with.I was not able to find a link to download it on Ansoft's
website.Can anyone mail me as to where can I get the version 7/8 of
Ansoft ensemble SV.Thank you.
mogwai
Full Member level 3
Greece
ensemble ansoft
Ensemble was Ansoft's EM planar simulator prior to their Designer suite.
Now, Ensemble (as well as Serenade - their old system/circuit simulator) are both incorporated together to Ansoft Designer.
You can get Ansoft Designer SV from:
https://www.ansoft.com/ansoftdesignersv/
cheers!
mogwai.
mr_ghz
Full Member level 5
ensemble 7 ansoft
Hi mogwai
That's true, but with the student-version of Ansoft Designer you can't simulate microstrip antennas...
dr_em
Junior Member level 2
New England
ensemble sv
As requested.
Better late than never. :)
Hopefully this helps you in your endeavors, if not you might want to give sonnet lite a try. You can get it from their website: sonnetusa.com - I think its much more capable and easier to use.
Good Luck!
dfmona
Junior Member level 1
ansoft’s ensemble
hi , i need to know if you guys could help me, i need tto know a good software were i can simmulate an array of microstrip patch elements, im designin a wrap around antenna for omnidirectional puposes i havent found a useful an easy to use software, i though that ansoft desiggner SV was the answer but i havent found any tutorials, an the one i found didnt have anything on microstrip antennas plzzz help i need help
