Where I can find the ne5514 opamp?
neazoi
Advanced Member level 6
Greece
ne5514 opamp needed
hello I need 2 to 4 pieces of ne5514 quad opamp.
I have found them on ebay very expensive.
Is there any other electronics site I could try or does anyone have them available for selling?
ne5514 opamp needed
Most likely many other OP types can be used instead, but there's no general replacement. You have to analyze the application requirements.
Re: ne5514 opamp needed
yes this is just for an active audio filter, but It is of low noise and quad amplifiers in one chip. Do you know of any other quad amp chip of low noise that can be used?
ne5514 opamp needed
I see, that the NE5514 noise parameters are only loosely specified. Another important parameter is required input impedance and the noise voltage to noise current ratio respectivly noise matching. An excellent low noise OP is OPA4227 for lower source impedances (<10k) and OPA4277 for medium impedances (>20k). For high impedances, JFET amplifiers (starting with good old TL074) are superior.
