Where did this CMOS device IV curve come from?
yellowperil
mos iv curve
Does anyone know how this curve come from?
This is Vcc vs GND IV curve using curve tracer. The device is only power up through the Vcc pin. [/img]
pmos iv curve
It seems to assume a quadratic behaviour, so probably that is the ID vs. VGS curve, i.e. the drain current versus gate voltage curve
cmos iv curve
A diode connection MOS. Id vs Vgs and Vgs=Vds
cmos curve
Hi jecyhale, can you explain further on the diode connection MOS? The MOS can cause a sudden constant current flow through the device like the graph show above?
iv curve of cmos
when you connect gate and drain of mosfet it behave as diode,untill Vt it is of then began to turn on
mos i-v curve
From your explanation, this diode curve occurs because the Drain is shorted to Gate?
Do you mind explain in more detail what is the purpose of this circuit (Gate short to Drain)?
