Where can I find the MatLab software which is compatible with Linux?
behy
Member level 2
Hi
where can I find the MathLab software which is compatible with Linux
thanks
hr_rezaee
Advanced Member level 3
Iran-Mashhad
MathLab
hi
do you mean MATLAB.
MATLAB is short of matrix laboratory.
regards
u04f061
Re: MathLab
behy said:
Hi
thanks
i havn't heared any software with name MATHLAB.
i think you have committed typing mistake (MATLAB).if you mean matlab ,then the linux version of matlab can be found at www.mathworks.com
however this is costly. in linux you can use an alternative to matlab with same syntax as matlab. the name of that software is gnu octvae at www.octave.org
however a student version of matlab is also available and can be requested at mathworks as well as some of universities also provide this
shaikhsarfraz
Full Member level 5
Re: MathLab
If you are planning to buy a license of MATLAB for linux OS then that is going to cost you some 4500 USD. (MATLAB 7 R 14)
Instead as somebody has already suggested use octave in place of MATLAB.
Thanks
Shaikh Sarfraz
dragonight_x
Member level 4
Egypt - Cairo
Re: MathLab
Actually there is a software called Mathlab ………. And I think you can check the company’s website for a version combatable with Linux
