MikeSD
Newbie level 3
I'm wondering if it's really this easy in deciding "IF" a heatsink is required.
I have a component (BTS555), that I'm using that has
Rjc = .4 K/W
Rja = 30 K/W
The device will be delivering a lot of current but the device itself will be disipating low power.
20A with 2.5 mOhm when conducting. Seems to be about 1W.
For a max junction temp of 150 deg. C and a maximum ambient of 85 deg C and using
Rja = (150-85)/1W = 65
If the part datasheet says that Rja = 30 K/W does that mean in this application that a heatsink is not required? The reason being that the required Rja is 65 but the component itself is already lower than the maximum resistance, according to the datasheet (i.e. 65 < 30).
Or conversly, does this mean that I could dissipate up to 2.1W before a heatsink was required?
Thanks,
Rjc = .4 K/W
Rja = 30 K/W
Thanks,
