when do we need to use CMFB?
knack
Member level 2
Austria
Hi there,
When designing a Diff. Pair amp., when should one use a CMFB ?
Thanks,
--Knack
You will need a CMFB circuit if u r designing a fully differential OpAmp, this is because you will two high impedance nodes and thus the dc level couldn't be maintained at a certain level
    knack
Sorry, I couldn't get what you said.
Please give more explanation,
Cheers,
--Knack
Cheers,
--Knack
You can check the chapter of the fully differential amplifier from Razavi, it is very well explained
    knack
CMFB is used to fix the output dc voltage level which comes from up and down currents mismatch.
and it can't be fixed through amplifier's negative feedback. so another feedback(CMFB) is used.
