When do we consider STA during FPGA design?
eeeraghu
Full Member level 4
I am into FPGA, Can u please say where the STA comes into the picture while implementing the design on FPGA, and what all the things i have to check for STA
Thanking you
Raghu
Shantha Rangarajan
Newbie level 3
Re: Where does STA comes
STA comes into picture when you you to analyze the timing delays, wire load models, see the net delays, faults, see if there is Set up/ Hold violation etc.
Shantha iyer
sr66
STA comes after you have done logic synthesis and also after place&route.
You can use STA when you have a gate-level netlist.
Use STA to check for setup, hold and pulse width. Basically use it to check if your design meets its timing constraints.
eeeraghu
Full Member level 4
STA can be done immedietly either after mapping or place and route,
Thanx for the help
bismillah
Member level 1
Earth
hi,
Can somebody post any reading material / books / links on this topic, thanks
yaseen1
Member level 1
In FPGA STA comes on FPGA SYnthesis
yaseen1
Member level 1
STA Comes during Synthesi
yaseen1
Member level 1
sta comes during simulation
askrkrao
STA Comes during Synthesis [/i]
love2read
Member level 2
STA check timing violations
nav_vlsi
India
STA COMES INTO PICTURE TWICE. ONCE DURING SYNTHESIS AND AGAIN DURING PLACE AND ROUTE.
SINCE SYNTHESIS TOOLS ARE THIRD PARTY TOOLS THEY DO NOT GIVE PRECISE DELAYS AND THE DELAYS ARE BASED ON WIRE-LOAD MODELS WHICH ARE APPROXIMATE.
P&R TOOLS ARE SILICON VENDOR TOOLS AND HENCE PROVIDE BETTER INFORMATION REGARDING THESE DELAYS.
regards
navien
Hards
Member level 1
STA comes after place and route and during synthesis, it analys your circuit it there is any setup time or hold time violation.
foster_cn
Member level 4
what is the STA tool for FPGA, like PT for ASIC?
satya_422
Member level 3
In FPGA Afetr Place and Rout Automatically Uses the STA tool to calculate the all timing issues and it gices all reports
