what's wrong with this GainBoosted OPA
wjxcom
Full Member level 5
Hi all: I am designing a GainBoosted OPA, now there have some questions that needed to be resolved!
The load of the OPA is 1.5pF, and the GBW of the OPA is 300MHz.
At first, I design the MAIN OPA of the GainBoosted OPA and the GBW of the MAIN OPA is 300MHz, the load of the OPA is 1.5pF, the phase margin of the MAIN OPA is 53.
After designing the MAIN OPA, I design Nmos_INPUT AUXILIARY OPA and Pmos_INPUT AUXILIARY OPA. The GBW of the Nmos_INPUT AUXILIARY OPA is 373MHz, the load of the OPA is 0.6pF, the phase margin of the MAIN OPA is 84; The GBW of the Pmos_INPUT AUXILIARY OPA is 381MHz, the load of the OPA is 0.6pF, the phase margin of the MAIN OPA is 84.
But after the simulation, I found that the The GBW of the GainBoosted OPA is 336MHz, the phase margin of the GainBoosted OPA is only 20(the load of the OPA is 1.5pF).
I think the pole and the zero shoul be at the unity-gain frequency, so if the phase margin of the MAIN OPA is 53, the phase margin of the GainBoosted OPA should be 53, I do not know why the phase margin of the GainBoosted OPA is only 20?
Help me, please. thanx!!
The full schematic and the netlist of the OPA can be found at the attachment: the gain_boosted.pdf is the MAIN OPA; the auxiliary_n.pdf is the Nmos_INPUT AUXILIARY OPA; the auxiliary_p.pdf is the Pmos_INPUT AUXILIARY OPA; cmfb_n.pdf is the CMFB circuit of the Nmos_INPUT AUXILIARY OPA; cmfb_p.pdf is the CMFB circuit of the Pmos_INPUT AUXILIARY OPA; the opa_bias_improve.pdf is the BIAS circuit of the GainBoosted OPA and the AUXILIARY OPA; balun.pdf can be used to AC simulation; the Gain_Boosted_ac.sp is the netlist of the OPA, and the csmc.lib is the library file of the OPA.
hr_rezaee
Advanced Member level 3
Iran-Mashhad
Hi
I think your aux. amp are in triode (I didn't simulae it, it is a guess.)
regards
    wjxcom
    V
wjxcom
Full Member level 5
Hi hr_rezaee: I have already simulate the aux.map, and I do not find the aux. amp are in triode.
why do you think the aux. amp are in triode?
regards
hr_rezaee
Iran-Mashhad
Hi
because
VGS6 of main is equal to VDG2 of N-aux amp.
so, VDG2=VGS6 and maybe bigger than VT.
regards
    wjxcom
wjxcom
Full Member level 5
Hi hr_rezaee: why VDG2=VGS6 and maybe bigger than VT??
I simulate the circuit, thay are in saturation region!
regards
wjxcom
Full Member level 5
Hi hr_rezaee, it is kind of you to reply my topic, thanx! the N-aux amp is in saturate.
I use Hspice and use .PZ to simulate the OPA, after the simulation, though a zero and a pole point were found at the 335MHz at the wave, I do not find the pole and the zero at 335MHz in the file .lis. I do not know why!!!
Help me please, thanx!!!
hr_rezaee
Iran-Mashhad
Hi
I simulate your circuit
I think you must reduce Wu of aux amps.
I'm not sure see Bult's paper .
regards
    wjxcom
wjxcom
Full Member level 5
Hi hr_rezaee: thanx you again to reply my topic!! At the same, what is the title of Bult's paper?
wjxcom
Full Member level 5
Hi hr_rezaee:I have read this paper. As descibed in this paper, if the unit frequency and the second pole of the main opa is w4 and w6, I make the unit frequency of the auxiliary OPA "wu" :w4<"wu"<w6. so in my design, the wu is 335MHz, and at the region: w4<"wu"<w6.
So hr_rezaee, would you help me again? thanx you!!!!
hr_rezaee
Iran-Mashhad
Hi
I reduced size of M00 in two aux amp. (it means that I reduced current of aux amps and so, gm of input transistor and so, Wu of aux amps).
and I saw that PM (pase margin) was too better than ago.
try this (you must redesign aux amps for better answer)
regards
    wjxcom
wjxcom
Full Member level 5
Hi hr_rezaee, I reduce the size M00 in two aux amps and I found that the PM is better than before!
But I have question: if I reduce the size, i.e. reduce the Wu of aux amps, then the equation (4) which was mentioned in the paper "A fast-settling CMOS op amp for SC circuits with 90-dB DC gain" writed by Bult wil not be satisfied, is it? so why the PM is better now??
Hi hr_rezaee, it's kind of you to help me, thanx!!!
jeffsky520
Member level 4
Hi, did u try to reduce sizes of M5~M8 in main AMP for better PM?
    wjxcom
hr_rezaee
Iran-Mashhad
Hi
I'm not sure
but I think you measure the band width of aux amps wrongly.
I think you must measure capacitance at the gate of M5, M6, M7 and M8.
then use this capacitor as load of aux amps.
maybe it helps you.
regards
    wjxcom
wjxcom
Full Member level 5
Hi jeffsky520: when I reduce the I use the sizes of M5~M8 in main AMP, then the gain of main AMP will be reduce!!
Hi hr_rezaee: I use this sentence to meare the capacitance at the gate of M5, M6, M7 and M8, i.e.
".OPTIONS POST BRIEF NOMOD CAPTAB ACOUT=0 CSDF=2 PROBE",
I'm not sure if my measure is right! would you give me some advice to measure the capacitance at the gate of M5, M6, M7 and M8??
thanx!!!
wjxcom
Full Member level 5
Hi hr_rezaee: I'm sorry to disturb you again! but what's your meas of "CAPTAB is good"?
thanx!!!
hr_rezaee
Iran-Mashhad
Hi
see simulation results:
captab:
0:eek:utnn = 1.4726p
0:eek:utnp = 1.4726p
0:eek:utpn = 2.0139p
0:eek:utpp = 2.0139p
auxn:
gm1=3.9659m Cl=1.4726p Wu=428.62 MHz
auxp:
gm1=4.8700m Cl=2.0139p Wu=384.86 MHz
main:
gm1=5.0128m Cl=1.5p Wu= 531.87 MHz
in bult's paper:
w3<w4<w6
see fig. 3
so,
it is a bad design.
redesign it.
regards
    wjxcom
