edwinvarghese
Junior Member level 1
- Joined
- Feb 27, 2014
- Messages
- 17
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 127
//CONTROLLER: PIC16F877A @ 16MHz Compiler MikroC
//original code : Warren Schroeder June 5, 2008
#define Servo0 PORTB.f0
#define Servo1 PORTB.f1
#define Servo2 PORTB.f2
#define Servo3 PortB.f3
unsigned int register volatile
unsigned int o=7,q=7,m=7,n=1 ;
unsigned short AllOn ;
unsigned short frame80 ;
unsigned short t0 ;
unsigned short t1 ;
unsigned short t2 ;
unsigned short ServoPos[4] ;
unsigned short ServoWrk[4] ;
char ch ;
void interrupt() {
if (AllOn) { // If AllOn flag=true then
PORTB = 15 ; // All PORTB servos ON
AllOn =0 ; // reset AllOn flag
frame80 = 0 ; // 80us frame counter
CCPR1 = 940 ; // 940us = 0 position
for (t2=0;t2<4;t2++)
{ // load work array from USART RX array
ServoWrk[t2] = ServoPos[t2] ; //
else {
CCPR1 = 80 ; // 80us frame delay (x 15 total = 1200us)
FSR = (unsigned short)&ServoWrk ; // servo pointer.. point to first servo pos
if (INDF == 0) Servo0 = 0 ; // turn servo OFF on 0
INDF-- ; // decrement position counter
FSR++ ; // point to next servo
if (INDF == 0) Servo1 = 0 ; // turn servo OFF on 0
if (INDF == 0) Servo2 = 0 ; // turn servo OFF on 0
if (INDF == 0) Servo3 = 0 ; // turn servo OFF on 0
if (++frame80 == 16) // finished 15 80us position periods?
CCPR1 = 17900 ; // load remaining time for 20ms interrupt
AllOn = 1 ; // turn ON all servos at next 20ms interrupt
PIR1.CCP1IF = 0 ; // clear CCP1 interrupt flag
void CCP1_Setup() {
CCP1CON = 11 ; // CCP1 Compare MODE with special event trigger; resets Timer1 on match
CCPR1 = 65000 ; // preload for 65ms delay before servo startup
T1CON = 32 ; // Timer1 Prescaler = 4 = 1us ticks
PIE1.CCP1IE = 1 ; // Enable CCP1 interrupt
PIR1.CCP1IF = 0 ; // Clear CCP1 Interrupt Flag
INTCON = 192 ; // Global & Peripheral interrupts enabled
T1CON.TMR1ON = 1 ; // Start Timer1...
void servoup1 ()
o++;
ServoPos[1] = o ;
if(o==15)
o=o-2;
void servodown1 ()
o--;
ServoPos[1] = o ;
if(o==0)
o=o+2;
void main() {
ADCON1 = 6 ;
CMCON = 7 ;
PORTB = 0 ;
TRISB = 0 ;
AllOn = 1 ; // all servos ON flag
UART1_Init(19200) ;
CCP1_Setup() ;
for (t0=0;t0<4;t0++)
ServoWrk[t0] = 7 ; // pre-load servo array with neutral position
while(1)
if (UART1_Data_Ready()) // If data is received,
ch = UART1_Read(); // read the received data,
switch (ch)
case 49: servoup1();
break;
case 50:servodown1();
break;
/*default: break;*/
void servoup1 ()
o++;
ServoPos[1] = o ;
if(o==15)
o=o-2;
