If it's a standard pyrolectric motion sensor it has more likely an analog output (source terminal of a JFET), intended to be connected to signal processing electronic, as shown in the Murata datsheets linked by bigdogguru. I'm not aware of a type with digital output, but it may exist.Check by giving the power supply (5v and Ground)
Connect the output to a led.
when motion detects the led should turn on otherwise no
