Whats the minimum NF for a CMOS LNA for 2.4GHz?
drabos
Full Member level 6
Full Member level 6
NF for LNA
Hello,
What's the minimum NF(Noise Figure) for a CMOS LNA for 2.4 GHz nowadays? (for example using 0.18 um CMOS technology)
Has anybody any idea?
What could the technology nowadays?
drabos
Full Member level 6
Full Member level 6
Re: NF for LNA
I've found a NF=3 dB LNA in 900 MHz. Could somebody a better value?
maddy
Junior Member level 1
NF for LNA
Hi
I have designed a 1.8 dB NF LNA for WLAN 2.4-2.5 GHz in 0.18 um Si CMOS. The measured NF was around 2.6 dB (indirect measurement).
Some SiGe process based LNA (MAXIM) for 2.4 GHz may have lower NF but thats a trade-off.
Regards
Maddy
    drabos
suhas_shiv
Full Member level 2
Full Member level 2
NF for LNA
Hi.
It depends on what kind of topology you are using. For 2.4Ghz, I have seen NFs around 2.5dB for differential and 1 dB for single-ended. I have designed a differential LNA with 2.8dB NF.
    drabos
maddy
NF for LNA
Yes Suhas is absolutely right. A lot depends on the full set of specs like power consumption, Gain, linearity etc.
Maddy
    drabos
ebalboni
Newbie level 6
Newbie level 6
Re: NF for LNA
For WLAN where you do not have big blockers the lna can have a lot of gain so the noise figure can be low. At 0.18um cmos a NF of 1.5dB is fesable. The input network Q will be high which can effect linearity as well as component variation sensitivity.
    drabos
drabos
Full Member level 6
Full Member level 6
Re: NF for LNA
maddy said:
Hi
Regards
Maddy
What's the indirect measurement?
maddy
NF for LNA
We used the Y-Factor method as the Spectrum Analyzer we used didnt have the Noise Figure personality and the Noise Figure meter. The shift in the noise floor is measured with the Noise Source (connected to the DUT) on and off. Then using a formula, the NF is calculated. This link below gives a brief overview. There is a appnote on NF measurement on Agilent website.
https://www.tutorialsweb.com/rf-measurements/noise-figure/noise-figure-measurement-techniques.htm
Rgds
Maddy
Added after 56 minutes:
*.. We didnt have a Noise figure meter.
    drabos
