What's the difference between KVL AND KCL?
joe1986
Full Member level 4
wht is the difference between KIRCHOFFS'S VOLTAGE LAW and kirchoff's current law??
difference between kcl and kvl laws
KVL means the sum of voltage across any closed loop is zero
KCL means the sum of current into one node is zero
    joe1986
KVL AND KCL???
KVL:
The sum of all the voltages in a closed loop is zero
KCL:
The sum of the currents leaving a node=the sum of the currents entering the node
i.e:
N1 N2 N3
o---/\/\/\/\/\/\--o---/\/\/\/\/\/\--o
I1 ---> I2 --->
here I1=I2
Sorry, the draw moves when i post it, but this is the idea
    joe1986
Re: KVL AND KCL???
KVL states that the sum of the elements voltage in a closed loop is zero but
KCL says that for a closed surface the algebraic sum of the currents are zero.
    joe1986
