what's the data in the sp file in IE3D
winglj
Full Member level 4
Hi, everyone. I just want to ask a simple question about the sp data in IE3D for 1 port structure.
Obviously the first column is the frequency points, how about the second and third? Are they the real part and image part of the S parameter, or the magnitude and phase?
And how about the meaning of the last few rows, such as:
! acs = 6 12 5 8 3 5 4
! insert_points = 3
! eps2d = 3e-005 3e-005 eps3d = 0.0001 0.0001
! max_factor = 2.5 extract_factor = 0.3 far_factor=0.7
! max_pts = 12 rate_pts = 2.5 next_ratio = 1.5 max_images=500000
! auto_fixed_lambda = 2089884024 increase_rate = 0.1 min_lambda = 100 max_lambda = 1e+006
Any help or just pointing out where the related informations in the Manual will be appreciated. Thanks in advance.
jian
Advanced Member level 3
Hi, Wingji:
The sp file is in the Agilent/EEsoft Touchstone file format. Those lines start with "!" are comments. In the .sp file, they are just some simulation conditions stored there. You can omit them.
Best regards.
    winglj
