Whats the best 8-bit MCU?
neoaspilet11
Full Member level 5
Cebu, Philippines
best 8 bit mcu
Guys,
I'm pooling opinions whats the best 8-bit MCU to use. I mean speed-wise, capacity, development support, cost etc.
I am currently using PIC18F67J11, whick I believed one of the best 8-bit from microchip. It has 128KB flash, 3900+ bytes of RAM, 2 SPI, 2 USART. Max speed of 12MIPS @ $2.79$ each. And the good thing I like this one is it is present in my favorite simulator proteus (only PICF6720 is modeled but very much the same as PIC67J11).
I am sure there are expert folks that can tell their opinions on what MCU is best for them.
Thanks,
neo
Slayerza
Full Member level 5
South Africa
the best 8 bit mcu
blueroomelectronics said:
Nice PIC, you'll need a decent programmer. Soldering those 100pin TQFP packages can be a pain.
Soldering TQPF can be a challenge but after a few its not really more difficult than other SMT devices.
Cheers,
Slayer
Kabanga
Member level 4
sodering tqpf
neoaspilet11 said:
Guys,
neo
I think you cannot just state that an 8-bit MCU is the "best" of all 8-best MCU !!
For me, and may be for many on that forum, "best" should be related to a particular application.
So, I'd advise you first to define what you want to do and then, only then you'd be able to find the "best" 8-bit MCU for your project !!!
If you define all parameters of your project, you may consider using MAPS of Microchip.
Best regards
Kabanga
ckshivaram
Advanced Member level 5
villingen (Germany) / Bangalore
avr microchip mcu better forum
everyone is comfortable with some or the other microcontroller which their project needs. Some may not be aware of controller which other talk or even know the features of that.
IT IS A MERE WASTE OF TIME POSTING THESE KIND OF THREADS WHICH ARE OF NO USE TO ANYONE.
By the way what is that you want to prove by this thread.
You can only judge the value of this post with the number of visitor for this thread and the number of replies you have got.
Let this forum be something creative or for helping the one in need rather than conducting some polling.
drbizzarow
Advanced Member level 1
best mcu
its depend onyour design requirement.
randell_xtian
Full Member level 4
Philippines
best mcu for application
it will depend on what kind of application you are doing. but i suggest that the ATMEL ATmega8 is the best microcontroller that i used.
becoz it has a:
-128k bytes ISP Flash
-32 x 8 GPWR+PCR
-16MIPS @ 16Mhz
-4k bytes of EEPROM
-4k bytes of SRAM
-2 SPI
-2 USART
- and it is cheap about $3.68 (US dollar) in philippines.
regards,
randell_xtian:D:D:D:D
nandhu015
India
microchip pic 2usart
Adding randell_xtian comment
which you find easy to use and easily available.
regards
nandhu
user1111
Member level 3
which is the best mcu
It depends upon your requirement and availability. but we would like to suggest to use AVR
freakkaito
Member level 1
holtek microcontrollers + indian prices
the best MCU is that MCU who can maximized the system, but if you asking me what i prefer choose to use i'll said i like MCS-51 fammily and ATmega fammily. it's simple, cheap and use full, and the important thing I can find that chip almost in the side of my country, include a small town hehehehehe
dian
Member level 3
Indonesia
best 8bit mcu
AVR for common application
gebepic
Member level 2
The Universe
lowest price 8 bit mcu
Pics are for me
But I have used few other Microcontrollers.
But as I looked , I cannot see more versatile nor comprehensively supported than Pic
Soft and HardwareWise.PRICEWISE too.:D
That is only my opinion ....
There are others that will disagree..as I look up here
Added after 10 minutes:
Seems to me that he got some interest .:D:D:D
Altafhal
Member level 2
Pakistan
top mcu
PICS are best but difficult to use
AVR and ATmel are easy to use but a little costly than pics
engg_pathy
Newbie level 3
india
mcu best
compared to Atmel,PIC is the easy avliable model in market.Samples, code examples also available on free of cost.We can find more models too. Encryption also not complicated in this type.
So, I suggest to go with PIC.
Computerman29
Full Member level 3
North Judson, IN USA
Here we go again!!!!!
There is no "Best 8-Bit MCU". What is best depends on the application.
Microchip's PIC is best for cost, versatility, and support.
Atmel's AVR is better for speed, but somewhat more expensive and harder to get.
TI's MPS430 is king of low power consumption and easy to get. (actually is is a 16-bit chip)
etc, etc, etc.
gebepic
Member level 2
The Universe
Returning ,after giving a chance to AVR first ...
I downloaded some simple ones.
I found quickly ::::
The most annoying for me NO INTERNAL OSCILLATOR !!!!
The 8 pins are limited to a very low count of input outputs and therefore reduce
the possibilities offered by the chip
Futher the versatility compared to PIC is near to nil.(in low end area at least)
And more !! the DATA SHEETS are also lacking in ........ DATA .
Need I say more ????
Sorry ... to the chaps who do not agree......
At least I do'nt say which is the best , I leave it to your imagination.....
I wont look any further..:cry:
rajtech
Member level 2
I like PIC16F877.. VERY GOOD MCU..
vandelay
Norway
Concluding that an 8-bit micro is better than another because it delivers more MIPS, has other peripheral interfaces, etc are meaningless at best. If it's speed you're after, I'd say the worst choice you've done is settling on a 8-bit micro, and if I only need one SPI - what makes a chip with 2x SPI better than a chip with one? It's most likely more expensive and has stuff I won't use. Same goes for RAM and flash. What I often do is using the devices with maxes out on RAM, flash, peripherals, etc for development. When my program works as intended, I optimize the code and RAM consumption. After that, depending on my final peripheral needs, I can settle on a device that looks just right for the job, usually the cheapest or most power efficient device that fullfills my requirements. That device is the best one.
EDIT: Also, 8-bit PIC and AVR is pretty much the same cup of tea. The best of the two is the device family you have programming experience with, since that device provides you the fastest development process, thus cutting down on development cost and development time.
gorkin
brazil
Recently I´m looking too Holtek flash micro... same core like microchip pic16 and low price!
Gorkin
