What's the advantage of using pga in sigma-delta modulator?
gingerjiang
Full Member level 3
hi all,
there is a pga(programmable gain amplifier) in front of sigma-delta modulator.
who will tell that the advantages of using pga?
thanks advanced!
Re: pga in modulator
renwl said:
increase the dynamic range.
can you explain it in detail?
thanks a lot
pga in modulator
little signal can be amplified to large signal for later processing. larger signal can be adjusted too.
so you can process a larger dynamic range.
    gingerjiang
