what's difference about mpeg2 v.s h.264?
mitsubishi
Member level 2
Hi anybody,
I want to design the chip of h.264. so i study document now.
Could anybody can point out what's difference feature in mpeg2 and h.264. On the other hand what's feature of simple profile and main profile. THX.
Best regards.
There are numerous improvement in H.264 (against MPEG-4 baseline)related to both coding efficiency and robustness to data errors, like:
- variable block-size motion compensation
- 1/4-sample-accurate motion compensation
- multiple reference pictures motion compensation
- weighted prediction
- moving of intra prediction in space domain, with 13/17 different modes
- in-the-loop deblocking filtering
- 4x4 integer DCT aproximation transform instead 8x8 DCT
- hierachical block transform
- exact-match inverse transform
- simplified quantization (no division but standardised division approximation with multipling and shifting)
- context-adaptive entropy coding (CAVLC, CABAC)
- parameter set and NAL unit structure
- flexible slice size
- flexible macroblock ordering and arbitrary slice ordering
- redudant pictures
- data partitioning
- SP/SI synchronization/switching pictures
- field coding
There are 3 profiles for now (profiles with more then 8-bit per pixels are expected):
1. baseline (doesn't support: B slices, weighted prediction, CABAC, field coding, SP/SI slices, slice data partitioning) - intended for conversational and streaming services
2. extended (doesn't support: CABAC) - intended for conversational and streaming services
3. main (doesn't support: flexible MB ordering, arbitrary slice ordering, redudant pictures) - intended for entertainment video applications (broadcast, DVD, video on demand)
Message is unavailable.
H.264 is more like MPEG4 rather than MPEG2.
h.264 is part 10 of MPEG4.
h264 MB : 4x4, 8x8 ,8x4, 4x8 etc.
DCT: integer
compress rate is better than MPEG2
