mad_scientist53
Newbie level 2
Hi all my 1st post here
I have a small cheap 1.2ghz video/audio R/X T/X unit. that I need to put the T/X in a small metal box with the antenna on the outside from the fac. the ant. screws on the unit which has what I think is sma but has a bushing to convert to I think is called "F" (it's the same size as a standard TV connector)and the ant. screws on it.
right now (because it's all I had) I have a 12"(really only need about 8") piece of 59 running between the T/X and a male to male adapter mounted threw the wall of the box with the ant. screwed on to it. It works but not sure if it will hurt any thing.
What would be the best coax to use and because it has to bend sharply most flexible
thanks
mad
thanks
mad
