Actually i wanted to know what type of tone would be available at pin 7. after constructed the circuit i gave tone o/p to input to the amp. but when i press the key it doesn't make any sense.. will it make sound if the circuit works?.. or let me know some ideas.. thanks..
Yes , it should give a DTMF tone sound, the familiar sound that you hear when you dial from your tone output telephone. You may need to connect two low value ceramic capacitors ( 10 to 20 pf)from each point of the crystal to ground. Also the tone output is open source, so you can connect a 4.7K resistor from pin 7 to ground and connect pin7 and ground to your amplispeaker.
Regards, Laktronics
