What type of Ports are used for HFSS S parameter analysis
hioyo
Dear Team,
In Ansys HFSS for S parameter extraction what type of Ports are used.
May I know the difference between waveport and lumped port.
HARI
Solution
I'm not sure what you mean by "PCB channel"; if you're using microstrip or slotline either would suffice. Generally, waveports are used for external excitations (that come from outside the domain), while lumped ports are used for internal excitations -- although these are somewhat flexible, as well.
Mostly, it is a matter of preference and accuracy to modelling your exact situation.
From the HFSS "Help" documentation:
Wave Port
Represents the external surface through which a signal enters or exits the geometry. It is effectively a semi-infinite waveguide attached to the model. This waveguide has the same cross-section and material properties as the port. Wave ports are placed on this interface to provide a means to link the model device to the external world.
Lumped Port
Represents an internal surface through which a signal enters or exits the device. It is effectively a lumped element for exciting the device and measuring S-parameters. For designs with only lumped ports or a combination of lumped and circuit ports, the Advanced Solution Setup, Options tab includes an option to use Enhanced low frequency accuracy.
Hi Planar,
Thank you very much.
What I understood from the above definitions is for PCB channel S parameter extraction we need to use Lumped S parameters.
Please correct me if I am wrong.
HARI
    hioyo
Solution
Hi Plannar,
Channel I mean if you are extracting the S parameters of DDR, then the path from processor to DDR.
HARI
If you're using a differential-mode CPS, I would either use a waveport exciting the differential mode, or a lumped port placed between the two lines.
Good Luck!
    hioyo
