What type of Capacitor
techie
Advanced Member level 3
Pakistan
100nk capacitor
Can I use the follwoing capacitor for decoupling purposes in digital circuits.
It has the marking 100nK 63. It is 100nf 63v
Besides this I have two other types in the same block shape but in blue and grey color. They show 0.1uF J.
How to tell what type of capacitor it is from the marking or shape.
penrico
Full Member level 5
Argentina
capacitor 100nk
Normaly, for decoupling capacitor in digital purposes, capacitors you can't are electrolitics, because it have a high inductando, so for high frecuencies over 1Mhz, electrolitics capacitors lose the capacity.
Use of ceramic or polyesters capacitors are good for decoupling.
In picture,it is apparently a NP0 ceramic capacitor, it means is a temperature compensated capacitor, is good for your need.
But it's inserted capacitor, so very high frecuencies will be not decoupled, cause the inductance in pins.
techie
Pakistan
100 nk capacitors
Are polyester film capacitors good for decoupling purposes. Or should one use only ceramic.
ME
100nk capacitor value
You can use polyester film caps as well.
pranam77
Advanced Member level 5
INDIA
100N = 100KPF = 0.1 Mfd. Its all one and the same. The photo given is of a polyester film capacitor. These types are well sturdy against temperature changes compared to Ceramic, and well suited for decoupling applications...Cheers
