What tool are you using to insert jtag circuit??
visualart
Advanced Member level 1
synospsys' BSD compile and the Mentor's BSDArchitect are the same stronng tools
zysmith
Member level 1
mentor's bsdarchitect
silencer3
mentors bsdarchitect is better one. u can have your own instructions and decoders is generated by tool. before doing JATG insertion, u must know what are all the instructions u r going to use and what is their decoding structure.
claint
Member level 5
BSD compiler which is integrated in DC.
wizard
Member level 3
China Mainland
bendrift said:
bsd compiler!
bsd compiler is bad when inserting some user defined instructions.Much manual work is needed.
Anyone agree with me?
Added after 5 minutes:
bsdarchitect is ok when handle user-defined instructions.
But it is very buggy, you can have it read the bsdl file generated by bsd compiler,
it issues an error message and fails. But I find the bsdl comply with 1149, no error
at all.
Anyone agree with me??
Added after 3 minutes:
Anyone could show me an alternative, other than these two??
ckim
Newbie level 5
This is old but, I thought I could help. These are the commands for adding user defined instructions in Synopsys. Simply specifying the register and the instruction definition will connect basics up for you.
set_bsd_configuration -ir_width 4
set_bsd_register INTERNAL -access { tdi, TEST_SI, shift_enable, TEST_SE, tdo, TEST_SO, capture_clk, TCLOCK } -cell U13
set_bsd_instruction { CLAMP }
set_bsd_instruction ITEST -code { 0011 } -input_clock_condition PI -register BOUNDARY -output_condition BSR
set_bsd_instruction ISCAN -code { 1010 } -input_clock_condition PI -register INTERNAL -output_condition BSR
set_bsd_instruction ATE -code { 1011 } -input_clock_condition PI -register INTERNAL -output_condition NONE
poluekt
Full Member level 2
Russia
I use dc 2009.06. Command set_bsd_register was excluded from BSD Compiler. What commands I can use for implementation access to core registers?
kornukhin
Full Member level 3
Zelenograd
Use set_bsd_instruction -register.
Here the example from DC-2010.03-SP4.
Before implementing a user-defined instruction, you must define the test data register
(UTDR) to which it is to be associated using the set_dft_signal and set_scan_path
commands, as follows:
set_dft_signal -view spec -type tdi -hookup_pin BIST/WRAPPER_0/debug_in
set_dft_signal -view spec -type tdo -hookup_pin BIST/WRAPPER_0/debug_out
set_dft_signal -view spec -type bsd_shift_en -hookup_pin BIST/WRAPPER_0/debug_en
set_dft_signal -view spec -type capture_clk -hookup_pin BIST/WRAPPER_0/clk
set_dft_signal -view spec -type bsd_reset -hookup_pin BIST/WRAPPER_0/debug_reset -active 0
set_scan_path DEBUG_reg -class bsd -view spec -hookup { BIST/WRAPPER_0/debug_in BIST/WRAPPER_0/debug_out BIST/WRAPPER_0/debug_en BIST/WRAPPER_0/clk} -exact_length 10
set_bsd_instruction DEBUG -code 1010 -register DEBUG_reg -input_clock_condition TCK -output_condition BSR
