I'd set the inputs with resistive dividers to obtain a high impedance output and in that way not have the device sinking current for nothing/wasting energy pointlessly.
Nice comparator with no phase reversal, by the way, thanks for bringing it to my attention.
Just saw that the TI pdf is about op amps, not comparators - while it's a delightful conversation topic (where does an op amp end and a comparator truly begin, is a comparator just an uncompensated op amp?, etc.) you are not using an op amp I think.
Look at the picture on page 32: op amp voltage follower (internally with some push-pull output stage or other). Now look at any old comparator schematic or typical application and spot the big difference: pull-up resistor (on an open collector output). Op amps are analog and linear input and output (hopefully) whereas the comparator is an analog linear input with a "cheapo" NPN inverter digital output.
All that waffle to explain why I think the ground voltage follower is not a good idea for an unused comparator.
