I'm seeing HFSSDesign1 and HFSSDesign2 under 'fast' and 'slow' models ... there is a restriction under "Mesh Operations" -> Length1 on "Element Based Length Refinement" for restrict length of elements to length=80mm for each HFSSDesign2 ...
Dave, which Design ran successfully (and fast) - 1 or 2? (BTW HFSSDesign1 failed for me on 'fast' a little bit ago using ver 13 hfss)
Jim
Thank You JIM. the maximum length in fast simulation is 247.8mm,which is over 3 times the max length of the meshrefinement upperlimit in the slow file.that could be the reason,just speculating here.got a gain of 7.62dB running the sweep now.simulation took just over 25 minutes to finish --> 'fast' file. my computer has i5 processor 64bit with 6 gig's of ram,hfss v13.
Start Time: 01/25/2012 16:00:12, Host skylark, HFSS Version 14.0.0
Executing from /opt/ansoft/hfss14.0/Linux/HFSSCOMENGINE.exe
Desired RAM limit not set.
Solution Basis Order: 1
Solution Sweep Discrete Sweep
From 0.3 GHz to 0.6 GHz, 60 Steps
<snip>
Solution Process Elapsed time : 08:42:40 , Hfss ComEngine Memory : 221 M
Total 08:38:09 38:20:14 Time: 01/26/2012 00:42:53, Status: Normal Completion
Could you post the Mesh statistics from the solution data for the slow file.since i cant finish the slow simulation.it will be even better if the whole solution data can be uploaded here for a good comparison.
Thanks a lot Dave.
Regards
Elchachito
