marleydc
Newbie level 5
- Joined
- Jun 25, 2009
- Messages
- 9
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,283
- Location
- United Kingdom
- Activity points
- 1,352
what switch
What sort of switch/relay uses the least power when it is not in the closed state?
I am creating a low power device (4V) and I want to switch devices on and off with it but, when the devices are switched off, I dont want to drain power from the battery.
I can use transistors as switches but I understand that there will be a contant current consumed by the quiscent current of the transistor even when it is off?
Are transistors the best option in this case? Or is there another cheap device that will not consume ANY current when it is not closed. Reed relay?
