Unlike FF Latch has no equivalent scan cell. So you cannot insert full scan during DFT if you se a latch.
Timing analysis can be done but is difficult than only FF design, as usually synthesis tools do "Time Borrowing" around latches.
check this page if u dont know time borrowing
To the new designer, latch is always a problem in synthesis. Check your verilog code. If you have a combinational always block which has one condition branch, you will get latch in the synthesis.
always @(a or b)
begin
if (a)
out = b;
// no else here will give a latch
end
So you can check your verilog code, and add a else condition for combinational blocks.
But experienced designer can use latch to reduce the design area. and get low power as well.
Latch is tough component in the design. It can give difficulty in DFT, timing and design. But it can save area and power.
