what should be the supply voltage ??
manish12
Advanced Member level 3
here is the diagram of led driver circuit
For std Red LEDs forward voltage drop of 2V is typical. So min. 10V should lit up the LEDs to full brightness. Since you're not controlling the brightness a current limiting R should be used.
Why do you use the upper PNP transistor?
Regards,
Laktronics
give the led details are they 3mm,5mm.....? normal,bright.....?
The PNP transistor is going to need a pullup on its base to LED + power. You also can't drive it directly from a 5V logic you'll need a open collector driver like a NPN transistor.
With 5 LEDs lets say White LEDs, so 5x3.1V+2x0.7V = 16.9V you'll also want it slightly higher so you can add a current limiting resistor so lets say 20V
