Register Log in
What needs to be taken care of in layout when doing layout of Charge Pump PLL?
vbhupendra
Full Member level 4
GOA, INDIA
What needs to be taken care in layout when doing layout of Charge Pump PLL ?
Thanks
holddreams
Full Member level 6
Shanghai
pll layout design
1.Introduction
2.Charge Pump PLL Linear Analysis
3.Phase Noise Analysis
4.Circuit Design and Simulation
5.Layout and Post-layout simulation
6.Chip Measurements
7.Conclusion
    V
nadavb
Newbie level 1
pll layouts
where can I get the file?
Thank you
doho
example of pll layout
If you have a type II PLL, make sure you do layout to match up and down currents.
salem_eng1
Member level 2
Egypt
pll layout
Read this Paper it is good about Charge Pump PLL frequency synthesizer
protonixs
Full Member level 3
PH
pll layout floor plan
clock signals should neither be wired near the analog signals nor pass through them.
clock signals should not also be near to each other. observe double space bet them.
Reactions: tt62 and mads
    mads
    tt62
Meme69
Newbie level 2
pll layout
What kind of PLL?
replyanil
Member level 1
layout placa pll
in what technology u want to make
climber73
Junior Member level 1
Europe
pll sg
Take about the position of your Charge-Pump Vs other sensitive block like VCO, divider and other.
Bye
rania_hassan
Egypt
what is a pll layout design?
Kindly find this layout guidelines you can take some of them according to your case
1. CP
Matching the current mirrors
2.Filter
Common centroid Layout for the Capacitors & resistors
Use Resistors Dummies
3.VCO
Keep it away from any nose source like Dividers and clock trees
matching for the diff pair (if any) but not to use inter-digitized
4.DFF (if any)
make the clk & Data entered the block from same direction to avoid negative skew
5.PFD/CP
Try to compensate any delay between up & down signals to avoid the reference spurs
Hope It will be useful for you all
best regards,
Rania
