T
treez
What material (double sided sticky) can we use to micro gap an SMPS Forward transformer?
The following threads show that generally speaking , its advantageous to have a tiny gap in a Forward converter core. (Standard ferrite lapping process means that you have a gap in “Ungapped” cores anyway, if only at microscopic level)……
https://www.edaboard.com/threads/push-pull-start-up-issue.348624/#post-1489330
https://www.edaboard.com/threads/tw...verter-with-bootstrap-high-side-drive.340530/
https://www.edaboard.com/threads/gapping-a-ferrite-core-for-full-bridge-smps-transformer.341980/
We were going to use a bit of kapton as a shim between all joining faces (centre and outer legs) but its awkward to cut up and not double sided sticky.
Is there an ultra-thin double sided sticky tape that can fill this purpose?
