What kind of triac should I use with this light dimmer circuit?
NTFS
Member level 3
Hi all
I made this circuit to be a light dimmer but it did not work. I use BT136 for the SCR and MOC3022 for optocoupler.
Can you tell me what is the problem? may be I should use another SCR.
jzaghal
Full Member level 2
Re: what kind of triac?
Try a BTB16/600 or BTA16/600.
The difference being the middle pin connected to the tab or not.
Check datasheet.
Bye.
vaibhav.k
India
what kind of triac?
please tell voltage at pin no 1 and 6 of Opto when supply is connected
CMOS
Advanced Member level 3
USA
NTFS said:
Hi all
I have tested this circuit with BT136. It worked.
Most probably you must have interchanged MT1 and MT2 terminals of triac and thats why its not working.
dumi
Member level 3
Me too I have tried but it doesn't work,i am using PWM 12V and 1mA to power my moc3023
prmurthy
Full Member level 5
Please use non-zero cross TRIAC Driver. Also remove the snubber.
Thanks
dumi
Member level 3
why remove the snubber?
prmurthy
Full Member level 5
Snubber is required for inductive loads and not for resistive loads.
Thanks
