What kind of sensor would be the best for measuring distance?
Peder
Junior Member level 1
What kind of sensor would be best to use to measure distance? It would not have to measure more than 5m but must have a tolorance of 2mm.
Re: Distance measurement
The best solution is Ultrasonic Sensors (Peizo-electric type) working at 40 kHz..
My graduation project in BSEE was in that topic.
They can provide high range of detection with high accuracy with careful design.
Go for it...
Or u can use IR sensors, which I doubt they can detect up to 5 meters (10 meter flight in Echo ranging)
Your call...
Good Luck
    Peder
@Kryptonite
Can you please send the project report
vsmGuy said:
@Kryptonite
I will post it in a separate post on EDAboard (G.o.d.-willing)... just give me a couple of days...
I will post the link here, so keep watching this topic :)
Of all that you do: don't forget to POST it :)
Thanks !
2 mm accuracy (assume the tolerance is accuracy) using if i am not wrong, open type sensor dollar cost sensor ? What the obstacle the distance is measured ? SPL generated by transmitter ? receiver sensitivity ? what the signal processing part of the unit is based on ?
@Kryptonite : Have you forgotten something ?
Am terribly sorry! Just got relocated to another country recently looking for a new job... no luck yet!
here's the link to the post where i uploaded the final report & presentation slides.
hope it helps!
Regards,
