What kind of opamp is that ?
wael_wael
Full Member level 4
hi,
could some one till me what is the kind of this opamp, it used for gain boosting op amp.
regards
op amp question
Both circuits are common source amplifier. They are used at times, as the output stage of two stage amplifier.
    wael_wael
Re: op amp question
but in the paper mentioned that is inverter
op amp question
yes,it's a common source amplifier.it's also a inverter.you must understand that inverter is also a amplifer,it's classB amplifier.note:if v2 and in tied together it is a inverter.
    wael_wael
Re: op amp question
thank you so much for ur help, but which way i use to design it, inverter or common source.
regards
op amp question
you can design common source
    wael_wael
Re: op amp question
thank u but i think is current source inverter which is the target now, but how ??
op amp question
Hi
you mus find your challenges.
they may be bandwidth, gain and bias in gain boosting.
because of negative gain, this amplifier was named inverter too.
regards
    wael_wael
op amp question
i think, in digital signal mode it works as an inverter (input 0 => output 1; input 1 => output 0). if u want the same circuit in analog signal mode operation, it will be a common source amplifier. In digital mode u no need to worry otherthan speed (load capacitance), but in analog mode operation u should take care of somany things as explained gain, ugb etc...
    wael_wael
Re: op amp question
The gain of both circuits is gm*ro/2. The transconductance is different though.
    wael_wael
Re: op amp question
Its the senario u r using this ckt for digital or analog application. Certnly its output bufer stage bcoz of high sizes and CS config. Csink and source txs are having high Gm s if u see it .
    wael_wael
Re: op amp question
hi,
thanx.
Re: op amp question
wael_wael said:
hi,
regards
These are not OPAMPs.
They are common-cource amplifiers.
Could you provide the schematic of your gain-boosting OP?
Re: op amp question
it is the second stage of an opamp in general used for the increasing the overall gain of opamp although it is not only the case for gainboosting
