saulbit
Member level 4
You are right! I just simulated the atc 600s 0603 high q ceramic capacitors using their s-parameters touchstone file, sadly found there is no capacitor can work from 3GHz to 18GHz. I took off all the ceramic capacitors in the rf lines with coil strips soldered in their original places. However, the insertion loss is much higher than 2dB, about 10dB for 18GHz.I agree regarding the VNA measurement.
But there are some issues with your PCB:
The cheap connectors plus this awful soldering are not appropriate for 18 GHz circuits.
The C61||C62 layout discontinuity is bad RF routing from a parasitics/controlled impedance viewpoint, and the components in parallel might create funny resonances with one of them becoming inductive above SRF.
