What is VITAL and what is it used for?
vcnvcc
Full Member level 2
VITAL - VHDL/VERILOG Initiated Towards ASIC Library,
But what is the use of it, How, and why??
Thanks..
Re: What is VITAL
What is VITAL
VITAL is for VHDL, not verilog.
Re: What is VITAL
Thanks..
The intent of VITAL was to provide a set of standard practices for modeling ASIC primitives, or macrocels, in VHDL.
Writing of component models.
The use is for board level verification of FPGA.
Re: What is VITAL
https://www.doulos.com/knowhow/faq/vhdl_faq/
"This is probably the biggest hurdle that many hardware engineers face when moving to VHDL. After all, sometimes we need to be able to describe actual implementation as well as abstract functionality. The way to describe "physical" hardware in VHDL is to write VHDL models of those components. This is supported in VHDL through the use of instantiation. VHDL does not allow you to physically simulate your hardware. You can only simulate a model of that component in a VHDL simulation. Historically, gate-level simulation using VHDL has been notoriously slow. This led to the creation of the 1076.4 working group to provide a mechanism to allow fast gate-level simulation using VHDL. Their effort became known as the VITAL standard. VITAL is not a VHDL issue for you, but an EDA vendor/ASIC supplier issue. A simulator is VITAL compliant if it implements the VITAL package in its kernel (this is faster than simulating the VITAL primitives in the VITAL package). You don't need to change your VHDL netlist; your ASIC vendor needs to have a VITAL compliant library though, in order for you to take advantage of the simulation speed up. Thus the ASIC vendor's library elements need to be implemented entirely in VITAL primitives."
