What is Verilog and where is it used for?
mkiani
Full Member level 1
what is verilog and where is it application?
banjo
Advanced Member level 2
verilog
Verilog is a hardware descriptive language. It allows digital logic circuits to described in a high level language rather than in individual logic gates.
The syntax of Verilog is very similar to the C programming language which makes it easy to learn. Originally Verilog was a proprietary language rather than an open standard. VHDL has always been an open standard and thus used to be more common for hobbyists and begineers. VHDL and Verilog do essentially the same thing, they are just different languages.
baonguyenpro
Member level 2
Re: verilog
Verilog and VHDL are Hardware Description Language to use for EDA
You write Verilog code and synthesis to gate level
jason99pan
Junior Member level 3
Re: verilog
In my knowledge, verilog is a kind of "Hardware Description Language". When you design the digital circuit, you can describe the circuit in verilog language.
deepu_s_s
Full Member level 5
verilog
hi,
Its jus like any programming language like c for example but it was intended to develop a schematic diagram of an IC
salma ali bakr
Advanced Member level 3
Re: verilog
Verilog is an HDL ( Hardware Description Language). It's used to describe digital logic circuits. After a Verilog code is written, it's simulated to assure functionality, and then it's synthesized to logic gates. These logic gates are then placed on an integrated circuit, operating and givng whatever function already described by the verilog code written earlier. That's the explanation in very simple terms :)
