what is this STATIC BYTE be doing here?
sachinkp21587
Member level 2
Member level 2
india (U.P.)
i am working on keil IDE using realview mdk-arm for a project based on LPC1768
i made a header file as below
#ifndef _test_h
#define _test_h
#include "diskio.h"
#include "spi.h"
#include "type.h"
#include "LPC17xx.h"
#define rcvr_spi()		xchg_spi(0xFF)
static
BYTE xchg_spi (BYTE dat);
#endif
and a .c file as follows
#include "test.h"
static volatile
DSTATUS Stat = STA_NOINIT;	/* Disk status */
static volatile
UINT Timer1, Timer2;		/* 1000Hz decrement timer */
static
UINT CardType;
#define xmit_spi(dat) 	xchg_spi(dat)
//#define rcvr_spi_m(p)	SPI2BUF = 0xFF; while (!SPI2STATbits.SPIRBF); *(p) = (BYTE)SPI2BUF;
#define rcvr_spi_m(p)	*(p) = xchg_spi(0XFF);
static
	return (BYTE)SPISend((uint8_t) dat);
now i made a main file in which i included this header file.
also by browsing added the c file to projects folder.
now when i make a call to xchg_spi there occurs an error saying
test.h(12): error: #114: function "xchg_spi" was referenced but not defined
the above compiles without any errors when the static is removed.
why so?
