What is the tools' name in Cadence Virtuoso for DRC
tia_design
parasitic extraction tool name of cadence
What is the tools' name in Cadence Virtuoso for DRC, ERC and LVS. I think those are specific tools embedded into Virtuoso. As for Mentor Graphics, the DRC is ICrules, and LVS is ICtraces.
edajason
Member level 3
cadence dracula
embeded one is Diva.
You can also use Dracula
z81203
Full Member level 5
yeah, diva & dracula. another is assura, but it's separated.
ambreesh
Full Member level 5
At present they are promoting Assura.
Other DRC tools from cadence are Dracula and Diva
nickbellamy
Newbie level 3
Well there are several which can be accessed in Virtuoso layout menus
(1) Diva
(2) Dracula
(3) Assura
Only (1) and (2) comes packaged with IC5033. (3) is in a separate software package and needs to be installed separately. Once (3) is installed and the path variables setup correctly, it can also be accessed via Virtuoso.
For small quick, on the job ie while designing a cell layout or analog parts DRCs and LPEs with diva is nice. Also Diva is interactive and do not need gdsII to exute. For anything larger ie complex digital circuits use Dracula or Assura. Dracula requires a GDSII file so you must export the layout first.
Assura is the replacement for Dracula.
For accurate parasitic extraction and full chip drc the only Cadence tools are Dracula or Assura.
In any case Calibre is still the main DRC tool for sign-off of any design
krrao
Junior Member level 2
hi,
embedded tools are diva and dracula.
we can invoke assura fm VLE if we have account of it.
yaxazaa
AssuraRF for inductance
