What is the simplest way to have an Ethernet connection on ARM with Keil?
baby_1
Advanced Member level 1
simplest way to have a ethernet on ARM with keil
Hello
what is the easiest way to configure ARM with keil function as ethernet controler (with PHY)?
I see different code but most of them make it's program complex. I need to config my ARM(smt32f10x) as a Server to receive and transmit some data not Telnet or webserver and etc.
Re: simplest way to have a ethernet on ARM with keil
If you want least code complexity, go for a small TCPIP stack like uIP or lwIP.
Reactions: baby_1
    baby_1
Thank you for you suggestion
As I download st "LwIP TCP/IP stack demonstration " I can't find Lwip stack and library files for smt32fxx as it mentioned
https://www.st.com/st-web-ui/static...ical/document/application_note/DM00036052.pdf
The source code for the LwIP stack can be downloaded at the following link:
http://savannah.nongnu.org/projects/LwIP
where can I download lwip for smt32 series?
