HI,
I am in the proces of designing a scrambler.
When i use the testbench to check the functionality of it,it works fine when inputs are passed as with certain delays.
The test bench is like this:
initial
begin
#20 descram_en = 1'b1;
ck = 64'h649dbdbe0cf0cfcb;
#20 descram_en = 1'b0;
#20 tspayload=1'b1;
area_sel = 2'b0;
scrambler_select = 1'b1;
data_in=64'h00000000_12345678;
#20 data_in=64'h6cbfa0e5_a96ddc60;
... i continue to pass the data in the same way. the clock is generated as:
initial
clk = 1'b1;
always
# 10 clk=~clk;
The code works fine for the above input.
When the testbench is changed as below the present state and the next state change simultaneously and ultimately i get the incorrect output.
initial
begin
wait(rst);
@(posedge clk);
descram_en = 1'b1;
@(posedge clk);
descram_en = 1'b0;
@(posedge clk);
tspayload=1'b1;
area_sel = 1'b0;
scrambler_select = 2'b01;
@(posedge clk);
... the clk is produced in the same module like above.
What is the reason for the present state and the next state to change simultaneously.Is the test bench correct?
regards
jesu
