what is the range of the capactiance is normally used in IC?
ug02048
Junior Member level 2
I would like to know what is the common range used in IC for Sample and hold capactor
any help is appereciated
Many thanks
Re: what is the range of the capactiance is normally used in
The size of your caps depend primarily on your required SNR, since in sampled circuits you have kT/C noise. Typical values are about 1pF.
cheers mate
it depends on technology. use KT/C and SNR spec to calculate it.
