Dec 2, 2016 #1 D Deexith Hasan Advanced Member level 4 Joined Oct 24, 2014 Messages 111 Helped 4 Reputation 8 Reaction score 3 Trophy points 18 Activity points 740 what is the real life range of nrf24l01+PA+LNA (one with seperate antenna) ? Its mentioned as 1.1km but some says you will get only 100m
Dec 3, 2016 #2 R Romansh Member level 3 Joined Apr 6, 2016 Messages 57 Helped 21 Reputation 42 Reaction score 21 Trophy points 8 Activity points 341 What is the gain of the PA, LNA and the antenna, once you know these, you can use a simple calculator: https://www.pasternack.com/t-calculator-link-budget.aspx
Dec 3, 2016 #3 A ArticCynda Advanced Member level 1 Joined May 8, 2013 Messages 439 Helped 82 Reputation 164 Reaction score 81 Trophy points 1,308 Activity points 4,238 Don't expect anything near the 1.1 km range, that is probably the maximum range in lab conditions with LOS using optimally dimensioned directional antennas. If you achieve one tenth in your application then you can't complain.
