What is the purpose of the tcl/tk in VHDL?
abhineet22
bangalore
tcl/tk
can any body tell me what is the purpose of this tcl/tk in vhdl ,and for making a command on this from where i start.
semiconductorman
Full Member level 3
Re: tcl/tk
In VHDL "nothing" ... :) .. TCL/TK is a scripting language ... It is genrally used to automate your runing of the environment for example ... you can write tcl scripts that can compile all your vhdl codes in modelsim rather than run all your modelsim commands every time you want to simulate . If you wish to use tcl first learn tcl , then you can probably make simple scripts
shelkerahul
Member level 4
Bangalore
Re: tcl/tk
As semiconductorman written Tcl/tk is scripting language, It has nothin to do with VHDL. My views are also same.
I am uploading the document for the Tcl/tk. It will help you
stormwolf
tcl/tk
tcl is "tools command language", which change a large work to some small work, so you can use those small work to do something. Now , all eda tools supple tcl, you just need learn some simple tcl , and how to use eda tools.
EcraZ
Full Member level 4
tcl/tk
tcltk is a scripting language and can be used for automating commands and making gui applications and interfacing with eda tools.
More information and the book **broken link removed**
pinkesh2001
Junior Member level 2
Re: tcl/tk
Specify what u want properly.There is nolink bet VHDL and TCL.
If u want to learn TCL take this document this will help u out.
Rgards,
Pinkesh
adap
Member level 5
Re: tcl/tk
Another book for Tcl/Tk that will help learning Tcl is the Practical programming in Tcl/Tk by Brent Welch.
See the attachment.
eziggurat
Full Member level 6
Re: tcl/tk
Modelsim has tcl/tk compiler built in. I managed to design a pop up GUI using a tcl/tk and Modelsim.
rprince006
Member level 4
Re: tcl/tk
Tcl/tk may be helpful for modelsim and design compiler users. However, I think unix-shell and perl are more helpful for all engineers in programming, design, and verification etc.
sunms
Junior Member level 3
Re: tcl/tk
vikram161
Newbie level 6
Bangalore
Re: tcl/tk
shield
tcl/tk
good materials, but search it in the web is so hard
HolySaint
Full Member level 3
Mars
tcl/tk
who have the highlight file for UE?
