Register Log in
What is the protocol for ethernet communication?
slhugo
Newbie level 6
what is the protocol for ethernet ?
does it request address then data characters ? how does it work?
do you send ASCII characters via serial port ? handshaking ? how do i respond to an Ethernet command ? is there a command list ? does it use commands ? i just don't understand it.
can anybody help me ?
Im pretty sure can handle the software and hardware development. i just need to
understand how to communicate via Ethernet
thank you
hugo
echo47
Advanced Member level 5
USA
ethernet protocol
Ethernet simply delivers a packet from one hardware address to another. It doesn't do requests or commands or handshake. You are probably thinking of TCP, which uses IP, which uses Ethernet. If you write a program in Windows or Linux (or some other networking operating system) that opens a socket and talks to another computer, then your program is most likely using TCP or UDP.
Do you really want to learn networking protocols (that's a big project), or do you want to learn to write a Windows or Linux program that opens a TCP or UDP socket and talks to another computer (that's usually easy)?
slhugo
Newbie level 6
Re: ethernet protocol
thank you
i need to communicate via ethernet between my own 8051 based circuit design
and a PLC (allen bradly or GE mfgs)
hugo
cancel
Full Member level 5
ethernet protocol
you can use e.g. ENC28J60 which is single chip spi/ethernet converter
slhugo
Newbie level 6
i will check it out
ENC28J60
thank you cancel
echo47
USA
ethernet protocol
Ok, a microcontroller project. Forget what I said about Windows and Linux.
I'm guessing that Ethernet won't be sufficient, and you probably also need Internet such as TCP or UDP. Here's an all-in-one chip that provides Ethernet, IP, TCP, and more. I've never tried it. It's looks easy-to-use, but not high-performance:
http://www.iinchip.com/
saubhik
Full Member level 3
India
thank you
hugo
Friend I had done a small program using Ethernet - WINSOCK in VB6 using UDP protocol , may be it wiol help you to understand how datatransfer happens in Ethernet .....
Best of luck ......
Toggle Sidebar
