Serwan Bamerni
Member level 2
- Joined
- Dec 21, 2014
- Messages
- 45
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 367
Hello everyone
Dear all Xilinx users
when i investigate the synthesis report of my project
i saw the following values
FlipFlops/Latches : 71
# FDC : 1
# FDCE : 50
# FDE : 20
in which I have a large number of FDCE and FDE, although I didnt infare such number of flip flop.
how this large number of flip flop is infared
below is my code and it can be seen that i never use such number of flip flop
also how one can decrease the number of FDCE and FDE
# FDC : 1
# FDCE : 50
# FDE : 20
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use std.textio.all;
use work.fixed_pkg.all;
entity Fixed_point_lefting_scheme_5_3_fast_hdl is
GENERIC (n : INTEGER := 10);
Port ( clk : IN STD_LOGIC;
s_set : IN STD_LOGIC;
input_s : IN STD_LOGIC_VECTOR (n-1 downto 0);
even_output : OUT STD_LOGIC_VECTOR (n-1 downto 0);
odd_output : OUT STD_LOGIC_VECTOR (n-1 downto 0));
end Fixed_point_lefting_scheme_5_3_fast_hdl;
architecture Behavioral of Fixed_point_lefting_scheme_5_3_fast_hdl is
signal sel_ena : STD_LOGIC;
begin
stage_selction: PROCESS (clk, s_set)
begin
if (s_set = '0') then
sel_ena <= '0';
elsif (rising_edge(CLK)) then
sel_ena <= not (sel_ena);
end if;
end process stage_selction;
lifting_scheme: PROCESS (clk,s_set)
VARIABLE odd_o1 : ufixed (n-4 downto -3);
VARIABLE even_o1 : ufixed (n-4 downto -3);
VARIABLE odd_o2 : ufixed (n-4 downto -3);
VARIABLE even_o2 : ufixed (n-4 downto -3);
VARIABLE sum_eo1_eo2 : ufixed (n-4 downto -3);
VARIABLE odd_o3 : ufixed (n-4 downto -3);
VARIABLE even_o3 : ufixed (n-4 downto -3);
VARIABLE sum_oo2_oo3 : ufixed (n-4 downto -3);
VARIABLE temp_value : ufixed (n-3 downto -3);
BEGIN
even_o1 := (others => '0');
odd_o1 := (others => '0');
even_o2 := (others => '0');
odd_o2 := (others => '0');
even_o3 := (others => '0');
odd_o3 := (others => '0');
if (sel_ena = '0') then
even_o1 := to_ufixed(input_s, n-4, -3);
elsif (sel_ena = '1') then
odd_o1 := to_ufixed(input_s, n-4, -3);
end if;
case sel_ena is
when '0' =>
temp_value := (even_o1 + even_o2);
sum_eo1_eo2 := temp_value(n-4 downto -3);
-- multiply by alfa = 0.5
sum_eo1_eo2 := sum_eo1_eo2(n-4) & sum_eo1_eo2(n-4 downto -2);
temp_value := (odd_o1 - sum_eo1_eo2);
odd_o2 := temp_value(n-4 downto -3);
temp_value := (odd_o2 + odd_o3);
sum_oo2_oo3 := temp_value(n-4 downto -3);
-- multiply by beta = 0.25
sum_oo2_oo3 := sum_oo2_oo3(n-4) & sum_oo2_oo3(n-4) & sum_oo2_oo3(n-4 downto -1);
temp_value := even_o2 + sum_oo2_oo3;
even_o3 := temp_value(n-4 downto -3);
even_output <= to_slv (even_o3);
when others =>
even_o2 := (even_o1);
odd_o3 := odd_o2;
odd_output <= to_slv (odd_o3);
end case;
end if;
end process lifting_scheme;
end Behavioral;
