what is the output of mux if select is X
raviram80
Member level 3
Hi All,
Can some one tell me what will be the output of mux if the select signal is X?
Thanks
svhb
Full Member level 5
The output should also be considered as X, since it is not defined what input should be used to send to the output.
RBB
Full Member level 5
USA
It depends on how the mux is modeled. It could be modeled such that if the inputs are the same, i.e. all '0' or all '1' and the select is 'X' then the output can be '0' or '1'. Like I said, it depends on how it is modeled.
aaronhe
Junior Member level 2
Shenzhen in China
I think In real world. the output can't be decided if the select signal can't be decided;
In library, it depends on model. I checked tsmc and arm library, there are no this "X" situation of select signal.
vlsi_freak
Full Member level 2
Depends on the model/library you are using.
regards,
freak
