For a dipole antenna with a coplanar line feed on a dielectric substrate I have to define a wave port. By changing the size the s-parameter will change as well. What is the reason? Theory?
Ok., on https://www.emtalk.com/waveport_calc.htm, there is one strip and I have two.
It is possible to use the distance between the two strips (outer region) as w?
You gave me a tool to calculate the wave size for one strip on a substrate with a ground plate.
Has somebody an idea how to determine the size of a wave port for a coplanar strip on a substrate without a ground plate?
I have no formula but for one strip you can use the tool on https://www.emtalk.com/waveport_calc.htm.
Has somebody a rule to create the ideal size of the wave port?
