What is the minimum required length for a waveguide to fully propagate the dominant?
bouchy
USA
Hi all,
What is the minimum required length, for a waveguide to fully propagate the dominant mode.
Thanks.
Bouchy
Re: Rectangular WG
To put it briefly ,the wide side of the wavelength must be longer than the cutoff wavelength of the dominant mode.
Re: Rectangular WG
Hi bluuice,
can you please explain you comment.
Thanks,
Bouchy
Re: Rectangular WG
usually, in a rect. wg, only TE10 mode is wanted.
Higher modes may be exited (but unwanted) and if exited they propagate itself.
Also Evanescent modes may be exited, but in any case they are strogly attenuated by the path.
How long shoud be the path to destroy Evanescents modes?
The answer require to set a level of accepted value (i.e. -40 dB) and a lot of complicated calculations.
As a rule of thumb, a path long a "a" side is enough.
Note that the evanescents modes (as every mode) attenuation is exponentially. So doubling the path, make a doubling of the attenuation in dB.
    bouchy
Re: Rectangular WG
hi sergio mariotti,
Thanks for the useful information. I have another question please, let say I design a RWG with cutoff frequency (freq1), width (a) and height (b=a/2). What will happen to my cutoff frequency if I change the height (b) to be equal (a/4).
Thanks for your support.
Bouchy
Re: Rectangular WG
bouchy said:
hi sergio mariotti,
Bouchy
Assuming you exite TE10 mode only, changing b dimension don't change cut-off frequency. So what change? Only Zo change.
    bouchy
Re: Rectangular WG
I have to agree with you, by reducing the height of the waveguide we reduce Z0.
beacuse Z0= (b/a)*the rest of the formula.
Thanks
bouchy
