what is the meaning of "weak"?
dechenxu
Newbie level 6
In the VHDL langguage, the std_logic type has 9 states including "weak high",
"weak unknown","weak low",etc. And i dont know the differences between "weak high" and "forcing high","weak low "and "forcing low" ,"weak unknown" and "forcing unknown". Can anyone help me? thank you!
dechenxu
hi,
in digital design, we have logic states {1,0,z,x}
which correspond to {5v,0v,z,(1.8-3)v} respectively.
in std_logic, we interpret the values (1.5-2.2)v as weak-zero. same explanation follows for the others also.
we usually come across these logic states only when you are working with some communication circuits.
else where, the standard states {1,0,z,x} will suffice.
let know us, when you get to know more.
"enjoy your work"
Alos keep in mind if you do syntizable module . then there is such a thing as week, only 1, 0, Z can be output, also you can not read 'Z" back
